jodicalhon
I have a small robot that I control via a TV remote sending Sony IR code. The robot has an 08M on board receiving commands via INFRAIN2.
0 = left, 1 = forward, 2 = right, 4 = reverse. Any other commands (3 for example) will stop the robot.
I am trying to control it from my computer. The idea is to send commands from the terminal program, contained in the Rev-ed programming software, via the serial cable to another 08M which will then send the command to the robot via INFRAOUT.
Obviously, I'm having problems.
Here's what I tried:
serin 4, N2400, b0 'accepts cmd from terminal
pause 200
for b1 = 1 to 10 'as per reved pdf 2
infraout 1, b0
pause 45
next b1
My 'bot beeps, as it should to show it has received IR, but no motor movement occurs.
After a few tries, examination of my breadboard etc, I then tried sending just the actual commands, not b0. That is, I changed the infraout line in the above to read:
infraout 1, 1
Whatever it received via serin, it just sent command 1, move forward. And the little bot moved forward as it should. Hmmm.
I tried the original approach again. No joy.
I got rid of the serin entirely, set up a switch on pin4 and coded:
if pin4 = 1 then revTry
for b1 = 1 to 10
infraout 1, 1 'bot goes forward
pause 45
next b1
pause 500
revTry:
for b1 = 1 to 10
infraout 1, 4 'bot reverses
pause 45
next b1
The bot moved forward until I pulled pin4 high, then reversed. So bot is receiving IR and responding to the commands.
I tried the initial code again. No joy.
Maybe infraout doesn't like sending b0; maybe it just likes things like 1, or 4, or 3, etc? More experimentation. Next try was.
for b0 = 0 to 4
gosub irOut
pause 500
next b0
irOut:
for b1 = 1 to 10
infraout 1, b0
pause 45
next b1
(This code is from memory, so the pause 500 may have been in a different place, but the intent is plain I think).
Receiving these signals, the 'bot cycled through 'left, forward, right, stop, reverse', as it should.
Tried the original code. No joy.
Hmmm. Maybe the terminal is sending crap to the transmitting 08M? So I added this to the original code, just after the infraout routine:
serout 1, N2400, (b0)
When I sent a '1' (fwd) from the terminal, my bot beeped (receiving IR), and a '1' popped up on the terminal input window. No movement from bot, however. I tried sending a '4'(rev), again the bot beeped and a '4' popped up on the terminal input window.
So the tranmitting 08M seems to be getting the correct data from the terminal.
I'm totally lost, but having read through the above I think I can say that the bot only fails to respond when the commands are coming <i>from the terminal program </i> to the transmitting 08M. But using serout to loop back those commands to the terminal input window seems to say that the correct code <i>is </i> being sent.
Bet it's something really basic, and you've been sadly shaking your head as you've read the (long) sad tale above!
Edited by - Jo C on 29/09/2006 14:24:06
pause 200
infraout 1, b0
pause 45
next b1
infraout 1, 1
for b1 = 1 to 10
pause 45
next b1
pause 500
revTry:
for b1 = 1 to 10
pause 45
next b1
for b0 = 0 to 4
gosub irOut
pause 500
next b0
irOut:
for b1 = 1 to 10
infraout 1, b0
pause 45
next b1
