@Hippy,
For what it's worth, whilst browsing I noticed the following inconsistency:
Picaxe Home > Datasheets > Exemplar Student Projects
Fish Tank Heater
On the circuit diagram, the Picaxe 18 shows “in 1” from the Serial temperature firmware, and “out 1” to the green LED on leg 7 of the IC package.
No hint of the Serial temperature firmware seems to be available anywhere on the RevEd site. It does seem to be a bit of overkill, but not unreasonable. Did the Picaxe 18 not have a readtemp command?
In the program listing, the symbols “delay” and “counter” are redundant, not being subsequently referred to in the code.
I also notice that the +6V supply to the Picaxe chip appears to be at variance with the current Manual #1 recommendation on page 8 "Power Supply" not to use 6V, 7.2V or 9V battery packs, as these could permanently damage the chip.
Could this example perhaps be brought up to date with the 18M2 part in order to provide it's undoubted original intention of assisting young students?
I did surmise that the 08 or 08M part may have been the basis of the Serial temperature firmware, but that would have meant that the circuit was able to only read the DS18B20 One Wire Protocol chip on leg 2. I'm vaguely interested in the history of that bit of firmware if you remember it after ten years (eek!). The pdf is dated 2001.
I'm sure that you are grateful for me spotting this and that it will go into the black book of things to address, but I have to warn you that encouraging me is likely to be a frustrating pursuit as I will doubtless pour over some of the datasheets and after a while you will begin to lose patience with me. It's a bit like scorpions stinging, it's apparently just what they do . . .
Keep up the good work.
Fish Tank Heater
