static issues
surgeon
my picaxe 28X1 keeps detecting a false signals and starting the next program segment, however it doesn't do it whn it connected to the download cable. does anyone know how to stop this?
BrendanP
Try decoupling capacitors across the supply pins, 10n and 100n and also a 100n on the reset pin. I had a similar problem to yours a while back and this fixed the problem. I use decoupling caps as standard now on all picaxe projects.
surgeon
problem solved
thx I grounded all floating pins and grounded the problem input with a small value resistor.
BrendanP
I should of specified that the inputs, if tied high, should be done so with a current limitng resistor, say, 10K.
Glad to hear you got the problem under controll.
