ssd1306_picaxe40x2 solar heater
andrefcarvalho
I'm trying to get the code to read the conditions, after adding a maximum setpoint condition the code doesn't work for me as I want, any solution?
    SYMBOL  tpan = w12'variavel word temperatura de painel
    SYMBOL  tcil = w13'variavel word temperatura de cilindro
    SYMBOL  setpoint = w14'variavel word temperatura de setpoint
    SYMBOL  man = pinC.0 'pin man/aut
    SYMBOL  pump = D.2 'bomba
    SYMBOL  temp1 = D.0 'sensor temp painel
    SYMBOL  temp2 = D.1 'sensor temp cilindro
bomba:
    sertxd("painel=",#tpan,"c ","cilindro=",#tcil,"c ","setpoint=",#setpoint,"c ","bomba=",#b32,13,10)
    pause 50
    #rem
        readtemp12 temp1, tpan 'painel
        let tpan = tpan*10/16 'calculo para valores positivos
        readtemp12 temp2, tcil 'cilindro
        let tcil = tcil*10/16 'calculo para valores positivos
    #endrem
            let tpan=222
            let tcil=223
            let setpoint=300
            if tpan >= tcil and tpan <= setpoint then goto P_on
            if man = 1 and tcil <= setpoint then goto P_on 'def de 1=man./ 0=aut.
            if tpan <= tcil or tpan >= setpoint then goto P_off
    P_on:
        b32=1
        low pump 'bomba ligada
        goto bomba
    P_off:
        b32=0
        high pump 'bomba desligada
goto bomba
Aries
The obvious thought is "what is the value of man?" In the simulation, it will default to zero. In the real world, it depends on how pinC.0 is connected. If it happens to be at a voltage high enough to appear as logical 1, then your code will always fall through to P_on, which is what you appear to be seeing.
andrefcarvalho
value for a toggle in manual, thanks for the help in it, there was no opportunity to come update the topic
Last night I was able to get the code working and I already have the truck to do its function, it seemed to be some problem in the output and I changed the pin
will work like this until i finish the board
23217
23219
23220
andrefcarvalho
Good afternoon, after some time using the board, I came across some problems in the truck, after some time littered characters start to appear on the lcd and the truck freezes.
Will I have something wrong with the code or wasn't it meant to work like this for so long?
johnlong
Hi and welcome
if I have understood your intentions correctly the following maybe of intrest to you
turn on and off within your values dependent on state of pin C.0
#picaxe 40x2
    SYMBOL  pump = pinD.2 'bomba
       tpan=220
      tcil=223
      setpoint=300
bomba:
    Do
    sertxd("painel=",#tpan,"c ","cilindro=",#tcil,"c ","setpoint=",#setpoint,"c ","bomba=",#pinD.2,13,10)
    pause 50
    #rem
    #endrem
          if pinC.0=1 then
                  if tpan>=tcil and tpan<= setpoint then
                    high D.2
                low D.2
        low D.2
    for b0 = 0 to 4 ;0 to 29
        pause 500;pause 2000 for a 1 minute delay
next b0
tpan=tpan+50;for simulation purposes remove
if tpan>370 then
    tpan=200
[code]
andrefcarvalho
Hi and welcome
#picaxe 40x2
       tpan=220
      tcil=223
      setpoint=300
bomba:
    Do
    pause 50
    #rem
    #endrem
          if pinC.0=1 then
                    high D.2
                low D.2
        low D.2
next b0
if tpan>370 then
    tpan=200
[code]
I have the slightly different code, yesterday I could not get from him, the question I have now is the truck send strange characters to the truck and then block, not doing its function, is normal?
andrefcarvalho
'                   zona de controlo para painel
'let setpoint = 360'usar em caso do valor na eeprom for absurdo, mais tarde tentar usar comandos serial
read 254, word setpoint ' define valor guardado na eeprom
pause 10
sensor_read:
                'let w12 = w12+offset 'offset de leitura
                'let w13 = w13+offset 'offset de leitura
    val_setpoint:
            if setm = 1 then
                sertxd("Setpoint=",#setpoint,"C ",13,10)
                goto val_menu
                goto val_write
            end if
            val_menu:
                    if up = 1 and dw=0 then setpoint_inc
                    if dw = 0 and dw=1 then setpoint_dec
                    if setm = 1 then val_menu
            goto val_write
            setpoint_inc:'incremento de setpoint
                if up = 1 then setpoint_inc
                setpoint=setpoint+var_inc
                goto val_write
            setpoint_dec:' decremento de setpoint
                if dw = 1 then setpoint_dec
                setpoint=setpoint-var_inc
        val_write:
                row = 6
                col = 7
            gosub setposition
                if setpoint >= 10 then
                aByte = setpoint / 100  // 10 + "0" : Gosub DisplayChar
                aByte = " "             : Gosub DisplayChar
                aByte = setpoint / 10  // 10 + "0" : Gosub DisplayChar
                aByte = "C"
                if setm = 1 then val_setpoint
                write 254, word setpoint' grava valor na epprom entrada 255
                pause 10
        bomba:' label  para defeni??o de estado consuante os sensores
                    if man = 1 then P_on 'vai ignorar o valor de temperatura dos paineis
                    if tpan <= setpoint then P_off'valor de setpoint para defenir que os paineis n?o trabalham antes do valor
                    if tpan <= tcil then P_off'valor de setpoint para defenir que os paineis n?o trabalham antes do valor
                    if tpan >= setpoint then P_on'valor de setpoint define a que temp os paineis come?am a circular a agua
            P_on:
                if tcil <= tempmaxcil then
                        b32=1
                        goto P_off
                    row = 5
                    col = 7
                        gosub setposition
                    for index = 67 TO 69
                        read index,aByte
                        gosub displayChar;
                    next index
                goto temp_1'para n?o passar o estado da bomba a desligado
            P_off:
                b32=0
                    row = 5
                    col = 7
                        gosub setposition
                    for index = 70 TO 72
                        read index,aByte
                        gosub displayChar;
                    next index
    temp_1:'display value painel
            row = 3
            col = 8
        gosub setposition
            if tpan>=10 then
            aByte = tpan / 100  // 10 + "0" : Gosub DisplayChar
            aByte = tpan / 10  // 10 + "0" : Gosub DisplayChar
            aByte = "."                   : Gosub DisplayChar
            aByte = tpan       // 10 + "0" : Gosub DisplayChar
            aByte = "C"             : Gosub DisplayChar
    temp_2:'display value cilindro
            row = 4
            col = 10
        gosub setposition
            if tcil>=10 then
            aByte = tcil / 100  // 10 + "0" : Gosub DisplayChar
            aByte = tcil / 10  // 10 + "0" : Gosub DisplayChar
            aByte = tcil       // 10 + "0" : Gosub DisplayChar
    sertxd("Painel=",#tpan,"C ","Cilindro=",#tcil,"C ","Setpoint=",#setpoint,"C ","Bomba=",#b32," ON=1 0FF=0",13,10)
    #rem
    if reload_inc < 65535 then ' limpeza de lcd
        inc reload_inc
    #endrem
goto sensor_read
lbenson
It's not normal. Can you post a good photo of the "strange characters"? What has the truck been doing when it gets the strange characters and freezes?
Hemi345
Since you're sertxd'ing some values, have you tried connecting your project to your computer when you see the OLED corrupted to see if the program is still functioning correctly? That would help determine that it is just your OLED code that is misbehaving.
Sorry but your code is very hard to follow/interpret with all the goto's mixed with gosubs. Another reason the program may go haywire is an overflow or variable you're reusing for the display. Try rewriting your program without using any goto statements.
It's not entirely normal but can happen. External events can cause hiccups in operation, lighting strikes nearby, ESD, power brownouts, induced electrical noise when something like a relay switches or a motor starts up, and so on. The longer a program operates for the greater the likelihood of such an event happening is.
If the controller on the display board has been thrown out of kilter it may not display what has been sent to it correctly even if the PICAXE is operating correctly. PICAXE operation may also be affected.
That this starts to happen after some time suggest the PICAXE program may have executed some part of its program which isn't doing as expected rather than some external event.
andrefcarvalho
I apologize for the time without answering, but due to the situation I could not come here, yes may be what the hippy is referring to, now I have had the device turned off, however maybe a way around the problem would be the truck doing a reset After a while, is it a good option?
