Y yurif74 New Member Nov 17, 2009 #1 i've 3 devices: two i2c and the third spi... how can i use them together with the same picaxe? is it possible? thank you
E eclectic Moderator Nov 17, 2009 #2 See reply #5 here: http://www.picaxeforum.co.uk/showthread.php?t=13512&highlight=SPI+I2C+mix There may be other threads as well. e
Technical Technical Support Staff member Nov 17, 2009 #3 The simplest solution is to use i2c via the hardware i2c port and then use the spiin/spiout commands on any other (different) i/o pins of choice.
