SPE030 using external speaker
ccdubs
Hi all,
I would like to use the SPE030 voice synthesisor module but want it to feed into a much larger amplifier so that I can broadcast the messages over a PA system.
Is it possible to tap into the audio output channel somehow?
Thanks.
Yes you can remove the onboard speaker and conenct into those pads/holes.
Keep in mind that the SPE030 outputs at around 5Vpp whereas audio amps normally operate at 1Vpp so a resistor divider will be necessary to reduce the voltage.
I have removed my SPE030 onboard speaker but replaced it with a 90mm piezo speaker for better volume and quality rather than feed into another amp.
ccdubs
Thanks WestAust,
I will check what voltage range we can send to our amp. At least I now know there is a way to tap into the signal. Removing the speaker will also give me some convenient mounting holes according to what I can see from the photo!
Thanks.
PS: sorry to hear about the Aussie/India test match....not really. If it's any consolation at least the Kiwis beat Bangladesh.
Regards,
CCdubs (NorthNZ)
