I bought a SOMO-14D about 6 weeks ago and it worked for about 5 minutes in pushbutton mode and then would not do anything. I just thought I had "blown it" somehow ???? and had almost given up when I noticed that users on this forum were also having problems.
Power supplies, SD cards, etc etc. Thanks to all who contributed to the previous threads I have it working again in serial mode and pushbutton mode. I have it working with a 08M using a modified program posted by "goom" to test if it would play the 6 demo files.
setfreq m8 ;make it run faster
; for picaxe 08m send data out pin1 and clock pin0 filenames for somo14d audio chip
; plays the six demo files
high 0 'make sure clock line is high initially (idles high)
;send volume control....vol = 5
W0=%1111111111110101 'The 16 bit data to send
gosub Send_Data1
sagain:
for b7 = 1 to 6 ; loop thro each file
if b7 = 1 then let W0=%0000000000000000
if b7 = 2 then let W0=%0000000000000001
if b7 = 3 then let W0=%0000000000000010
if b7 = 4 then let W0=%0000000000000011
if b7 = 5 then let W0=%0000000000000100
if b7 = 6 then let W0=%0000000000000101
gosub Send_Data1 ; send the filename
next b7 ; get next file to see how quick it is a switching
pause 10000 ;play last file for a few seconds
goto sagain
Send_Data1:
low 0
for b4=1 to 15 'Loop 15 of the bits
if bit15 = 1 then high 1
if bit15 = 0 then low 1
pulsout 0,40 ;Clock high for 200us to latch data on pin1
W0=W0*2 'Shift left to get next significant bit
next b4
high 0 ;latch in 16th bit and idle high
pause 10000 ;play for a few seconds
end
Also regarding SD Cards, the one I use is Fujifilm 2GB Micro SDcard, formatted FAT16 and works OK.
I have difficulty getting it to work on battery power, I have it and the 08M powered on a Uniross Model Uni505R Multi Output PSU set for 3 volt and voltage measures 3.1 volts.
The only connections are Data, Clk, Speaker and Power, no resistors or diodes ???
The application I have for it, I want it to switch as fast as possible "cleanly" between the files. I will work on that now.
I thought the above might be of interest to those who are still having problems
gosub Send_Data1
sagain:
goto sagain
Send_Data1:
low 0
next b4
end
