PcAx anothermarc
SOLDERING ALTERNATIVES
- CONDUCTIVE GLUE/SOLDERING PASTE ... ?
i am looking for a reliable, not-too-expensive alternative
for soldering connections
& found conductive glue/paste products as listed in the following;
i assume that there is nothing that really replaces
soldering but would like to know, if you probably
tested any of these or may recommend a specific
product suitable for "sticking" components onto pcb's
any hint is highly appreciated!
PRODUCTS
http://de.rs-online.com/web/c/?searchTerm=loet+paste&sra=oss
solder paste/ solder glue
... based on silver
http://www.ponoko.com/make-and-sell/show-hardware/2201-a-solder-paste-50g-leaded?source_node=ponoko_united_states#main-image
solder paste
... needs heat to harden out,
cheaper than silver based glue
http://www.thinkgeek.com/gadgets/tools/b70c/
"Wire Glue"
... does not need heat to harden out,
based on graphite powder,
cheapest of all i found so far
http://www.instructables.com/id/Make-Conductive-Glue-and-Glue-a-Circuit/
... selfmade, based on graphite powder
TESTS/RATINGS/COMMENTS
http://forums.reprap.org/read.php?70,21723
"Wire Glue"
... it's consistence might be too brittle,
using additional expoxy might make up with this issue
PRODUCTS
... based on silver
solder paste
"Wire Glue"
"Wire Glue"
