Harlequin_Hunter
I have been introduced to the PICAXE microcontroller via the use of Snap Circuits kits, whilst trying to learn more about electronics and coding. This project was an attempt to learn a little more about coding with PICAXE by setting a fairly simple task with a specific goal in mind. To reprogram the phrase set, in the Snap Circuits ‘6SCM8 Programmable Fan’ with a little automation.
The fan has five terminals, two for power and, 3 for programming. It comes from The Snap Circuits Arcade kit (SCA-200) which also contains the ‘6SCU29 LED Display and Microcontroller’. The microcontroller happens to be a PICAXE 08M2, which has just enough inputs/outputs for this idea.
You can download the manual from the Elenco website but it’s probably quicker to use google and search for ‘SCA-200 Manual’. From this manual, Project 15 details how to create a basic circuit to use and program the fan by hand and, instructions on the sequences required to program.
The character set used in my code only includes the capital letters of the alphabet and not all numbers and special characters that the fan can use. This is in part to simplify the code as there no simple conversion from ASCII characters to those used in the fan’s character set.
Before any coding could take place a method to interface the fan to the microcontroller was required. The ‘MODE’, ‘UP’ & ‘DOWN’ fan buttons connect the internal circuit to ground. My first attempt was to connect the U29 module to the fan inputs directly and keep all required pins high until a button press was needed. This did not work. The fan would not respond if any more than one button at a time was connected with this method, hence the addition of the diodes between the U29 outputs and the M8 inputs. I do not fully understand why but all works with the diodes in place. Three connections are required to program but an output was needed to switch the fan on and off, to reset all phrases to “ ” and ensure a datum point.
Once the circuit was made, and confirmed to work, the programming could begin. The fan buttons do have an auto-repeat function but it is not possible to set the characters using time (press and hold for so long to get a specific character), so separate pulses are required for each button press. The delays used are quite long, but shortening them, between the button presses and releases, causes the fan programming to become unreliable. This means that, even with this automated process, there is a significant time required to program all six phrases.
This project is likely to have more entertainment value than practical but, I have found it useful for setting a goal and, hopefully, moving beyond just following example programs.
Reference
Google search
LED-MC-info.pdf for information on the internal structure for U29
SCA-200 Manual.pdf for Snap Circuits Arcade Project Book
https://youtu.be/RvvTJTYCCNo
Reference
Google search
'M8 Programmable Fan Program to re-enter the default phrases'
'Changed code to use text instead of ASCII values
'Error checks to ensure only space / upper case characters are used
'The M8 fan has a larger character set but it's not compatible with ASCII codes
'USE ONLY CAPITAL LETTERS AND SPACES
'Code works with U21 & U29 uProcessors
#picaxe 08M2
'bytes 420 of 2048
#no_data
disconnect ;***Start program download before powering m/c!***
let dirsC = %00010111 ;C.0, C.1, C.2 & C.4 set to output
symbol upbtn = C.1
symbol modebtn = C.2
symbol fanswitch = C.0
symbol nextbtn = C.4
symbol shrtpause = 140
symbol medpause = 2000
symbol lngpause = 4000
symbol btnPress = b0 'to help with debug
symbol charNum = b1
symbol charPosNum = b2
symbol phraseNum = b3
symbol charAscii = b4
setint %00000000, %00001000
high modebtn
high upbtn
high fanswitch
high nextbtn
Main:
pause 2500
low nextbtn 'show next phrase if no button is pressed before 2500 ms @
pause shrtpause
high nextbtn
end
interrupt:
gosub setphrases
setphrases:
low upbtn 'reset all phrases
pause lngpause
high upbtn
pause medpause 'switch fan off to finalize reset
low fanswitch
pause lngpause
high fanswitch
pause medpause
gosub setpmode
snap: 'six phrases to program six alternate phrases
select phraseNum
case 0 lookup charPosNum,(" SNAP CIRCUITS "),charNum ; put ASCII char into b1
case 1 lookup charPosNum,(" ARCADE "),charNum
case 2 lookup charPosNum,(" BY ELENCO "),charNum
case 3 lookup charPosNum,(" LEARN BY DOING"),charNum
case 4 lookup charPosNum,("FUN ELECTRONICS"),charNum
case 5 lookup charPosNum,(" YOUR PHRASE "),charNum
endselect
gosub chkchar
if charPosNum < 15 then snap ; loop
if charPosNum = 15 and phraseNum = 5 then
gosub setpmode
else gosub nextphase
end if
inc phraseNum
if phraseNum < 6 then snap
chkchar: ;check capitals or space characters only
inc charPosNum ;increment position
charAscii = charNum ;hold ASCII value for Debug
select charNum
case 32 charNum = 0
case 64 to 91 charNum = charNum - 64
else charNum = 27 ;use '*' for any other character
endselect
gosub setletter
nextphase: 'move to next phase
gosub setpmode
low nextbtn
pause shrtpause
high nextbtn
pause shrtpause
gosub setpmode
movefwd: 'move Forward
low modebtn
pause shrtpause
high modebtn
pause shrtpause
setletter: 'program fan for spaces / letters
if charNum = 0 then
gosub movefwd
for btnPress = 1 to charNum
low upbtn
pause shrtpause
high upbtn
pause shrtpause
next
pause shrtpause
gosub movefwd
setpmode: 'enter / exit Programming Mode
low modebtn
; pause medpause
pause medpause
high modebtn
pause medpause
charPosNum = 0
