'Radio control servo slowdown
'PICAXE-08M connections are:
' Leg 1 +5V
' Leg 2 (Serial in) Tie to Ground through 10K resistor
' Leg 3 (In4/Out4) Wiper of 10K potentiometer connected to +5V and ground
' Leg 4 (In3) Pulse input from radio receiver
' Leg 5 (In2/Out2) Pulse output to servo
' Leg 6 (In1/Out1) Mode indicator output
'1/2 second flash = no valid signal
'Steady on = pass-through (no servo slowdown)
'Flicker = servo slowdown mode
' Leg 7 (Out0/Serial Out) NC
' Leg 8 Ground
symbol Delay=b8 'Name the delay factor
symbol PWin=w0 'Name the input pulse length
symbol PWout=b2 'Name the output pulse length
symbol PWinPrev=b3 'Name the length of the prior input pulse length
symbol PWinErr=b6 'Name the difference between input and output pulse lengths
symbol skip=b4 'Name the counter for skipping "Delay" times
restart:
Skip=0
high 1
servo 2,135 'Center the servo initially and on input pulse loss
Pause 500 'Wait 1/2 second initially
toggle 1
readadc 4,Delay 'Read the voltage from the delay potentiometer
pulsin 3,1,PWin 'Measure the input pulse width initially
if PWin<75 or PWin>225 then restart 'Go back if no valid input detected
high 1
low 2 'Stop the sevo command if valid input detected
PWinPrev=PWin 'Initially set the prior pulse width to current pulse width
if Delay<5 then StraightThru 'If delay pot set near zero skip slowdown routines
Delay=Delay/21 'Set delay to 0 (1.5s stop-to-stop) to 12 (20s stop-to-stop)
PWout=PWin 'Set output pulse to input pulse initially
loop_:
toggle 1
PWinPrev=PWin 'Reset the prior pulse width
PwinErr=PWin-PWOut
if PWinErr<2 or PWinErr>254 then StayPut 'Add 2 units of hysteresis
if PWout<PWin then MoveUp
if PWout>PWin then MoveDown
MoveDown: 'Routine to decrease the output pulse width
if skip>=Delay then Skip1 'Loop to delay change to Delay x 20ms input periods
Skip=Skip+1
goto Skip2
Skip1:
Skip=0
PWout=PWout-1
Skip2:
pulsout 2,PWout 'Send the output pulse to the servo
goto loop_ 'Return to re-measure the input pulse
MoveUp: 'Routine to increase the output pulse width
if skip>=Delay then Skip3 'Loop to delay change to Delay x 20ms input periods
Skip=Skip+1
goto Skip4
Skip3:
Skip=0
PWout=PWout+1
Skip4:
StayPut: 'Routine to send the same output pulse
pulsout 2,PWout
StraightThru:
pulsin 3,1,PWin
PwinErr=PWin-PWinPrev
if PWinErr<2 or PWinErr>254 then Stay 'Add 2 units of hysteresis
pulsout 2,PWin
PWinPrev=PWin
goto StraightThru 'Return to re-measure the input pulse
Stay:
pulsout 2,PWinPrev 'Set output pulse to input pulse
