So what projects are on their way ?
I have made a Ethernet controlled relay box,so I can control all the routers and stuff in the closet, and a led controller on its way.
Other ideas.
Temperature readings ofcause
Remote LCD? fairly useless probaly
Serial2Ethernet maybe
I was thinking of copying another project I did with a more expensive chip, but in the end it will just be for the project (graphs, sms/email alarm, based on ds18b20 sensors)
-biggest problem would be transfering the data to the client, since its too much to fit on simplelan even with all variables, so it would be udp sending or something.
Any bright ideas how we can protect the webpages if we put the little thing on a network where the webpage can be seen from the outside ?
Any javascript solution is insecure I guess, flash/java is a bit heavy.
Well shoot
Other ideas.
Well shoot
