I had a leaking water pipe in the crawl space that needed repair. Before I could get a plummer out, I needed to monitor the leak. It would have to be wireless because of the distance, complexity to run a wired senor to the spot.
I discovered some time ago a niffy, cheap wireless transmitter/receiver that I have used on several projects. This rf device is small and has a range of at least 50 feet, through walls. It comes with two dongles. One is connected to a PIXACE 08M with small isolation relays to simulate the button push (push one button to turn on, a different button to turn off) when the 08M senses a lower resistance. The senor is measured on an ADC input pin of the 08.
The Tr/RX module is the RM01 from Logisys. You can buy it from Geeks for about $12. http://www.geeks.com/details.asp?invtid=RM01&cat=GDT
The code is straightforward:
I have also used this setup for a wireless alarm sensor. Very useful!'08 14 bit0-15 b0-13 w0-6
' remote water sensor
st:
readadc 4,b1ause 100 ' read sensor
if b2=1 then goto jmp
if b1>10 then gosub ton
jmp:
if b2=1 and b1=0 then gosub toff
goto st
ton: ' turn on
b2=1
high 1ause 300:low 1
toff: ' turn off
b2=0:high 2ause 300:low 2
