I'm a little confused i must admit. I thought I was pretty well up on interfacing these with components but ive struck something I cant figure out. I have an IRLZ44Z to power a small lamp (Overkill, will be used with different load later).
http://www.irf.com/product-info/datasheets/data/irlz44z.pdf
I've hooked it up through output 4, simple test pulse of 250ms on, 250 off. I am driving Pin1 of the IRL (gate) with output 4 (through a 4K7 for safety, and pulled low with a 4K7). Pin 2 of the IRL (drain) is linked to the load, and then obviously to the +12 rail. The source, pin 3, is connected to the 0v rail. When i do this the lamp doesnt light and after some time the Pic gets damn hot. I unplug all wires and it remains hot until i unplug and replug, whereby it remains cold and can be programmed again no problems. All outputs work with an LED/res combo. The IRL should switch with ~2v gate voltage and has protective resistors so i have no idea why the pic is getting hot and the lamp not lighting?!? I've rewired this twice now and i still have no luck.
