I have an interesting problem that I will put out to the community for suggestions. I would like to place a sensor over a black or white square (created using toner on a laser printer), and get out a ~5V or ~0V signal. I would like to use the QRD1114 IR LED/phototransistor combo if possible (http://www.sparkfun.com/commerce/product_info.php?products_id=246), since I already have several of them. I would also like to do this using 1) only discrete components (no microcontrollers!), and 2) as few components as possible.
From my experimenting so far, the phototransistor doesn't *quite* saturate when it sees a white square (just normal photocopier paper), so I get like ~3V or so at the input (just a pull-up resistor to 5V on the collector, and emitter tied to ground). I basically need a 1-bit ADC =)
Suggestions welcome!
