While the PICAXE 40X1 I was using does have hardware SPI, I used a bit-bashed interface since we also need to control the other gLCD module pins.ok thanks.
So I can't see why my 3310 code doesn't work, since my supply voltage is 2,59V (a 3,3V regulator + diode).
Does your processor have built in serial interface that you're using(SPI)? My code has just some loops to write dserial data.
Have a look at the information in posts 6 and 9 relating to the hardware aspects of the interface - I did subsequently buy a 74LVC245A chip and remove the resistor based potential dividers on the 74HC245 inputs mentioned in post 9.
The program listing in post 10 at the top in the remarks gives the connection data as well.
Keep in mind also that a number of members on this forum who purchased some Nokia 3310 displays via Ebay or similar sources found there were some displays that did not work (DOA). If you know by say removal or testing in a working mobile/cell phone this the display is good then you should be able to get it working.
