Marmitas,
No pin was left unconnected. The IS471F device modules the IR transmission for you, hence the LED connected between Vcc and GLout.
Point the LED away from the device and shield for side (stray) IR transmission, then the device will pick up reflected IR from the object that's being detected.
Russbow,
TSAL 6400 looks spot on, I thought the TSxx 5400 was 950 nm but it shouldn't make much difference. We're jumping to a new problem when you start to talk about the TSOP devices.
Un-modulated IR is ok at close quarters where there is little excess from surrounding ambient lighting... 1-2mm at best 5(ish) depending on the actual device and set-up. They're often used for line following or minisumo edge detection but you're mounting close to the target.
As Hippy says, modulation helps you pick a signal out against back ground light levels. With object detection you firing your signal out into open space and hoping to pick out a reflection. How do you know what is reflected and what's not if there' no distinctive signal?
Considering your NE555 and detection using the TSOP xxxx, there are a number of things to consider. First tuning your components to give 38Khz output from the oscillator... breadboard will be a pain, there's so much capacitance before you start but it's not impossible.
Second is the off time, the TSOP will try to attenuate a continuous signal. If you're trying to keep your target in "sight" (or expect it to be there for more than say 600us) then you'll need to turn the signal off for a short period. The an 08M would make a good candidate for output as you can get a good match to the 38kHz and control the periods. I can't say I've had great success with the TSOP devices for object detection, I should try again but then they're not designed for this purpose.... I might try again. I've got a neat board made up for dual sensors but need to spend a little more time on setting up the period of modulation.
Purpose built object sensors may be a little bit more expensive but they are sooooo much easier to use!
The (missing) German site is the same site as I said was gone in my first post
the concept is still good
best regards,
colin
