Hi everyone. I've looked around and cannot find an answer to this: I'm working on an ROV using an 18M2 chip to control two thruster motors. I was looking at the Cytron Motor Controllers which seem to require PWM input vs a high-low signal to turn the motors on and off. As I only have one available PWM pin (the PCB is already built and the one other PWM pin is being used for something else), does anyone know if a single PWM output signal could be sent to two motor controller boards - each motor running at the same speed? Or would the output signal be de-graded if shared? These boards use a high-low signal for motor direction control and so that issue would be a slam dunk.
Thanks for any help. Here is a link to the Board I'm looking at: https://www.robotshop.com/en/cytron-13a-5-30v-single-dc-motor-controller.html#Multimedia
