Setint or
roho
Hello all,
Just to double check my understanding of this command. Device in question is a 14M2 and the exact command I'm using is:
SETINT OR 0x06, 0x07
My understanding is that this will interrupt when either of C.2 or C.1 are high or C.0 is low, or perhaps more pertinently in the circumstances, should not interrupt when both C.2 and C.1 are low and C.0 is high. Is this correct or am I misunderstanding something?
As an after thought, would:
SETINT NOT 0x01, 0x07
achieve the same aim?
Roger.
Yes, both commands are equivalent and will behave as desired. The quickest way to get confirmation is to try it, simulate a small test program under PE6 ...
#Picaxe 14M2
Main:
  Gosub Interrupt_Enable
  Do
  Loop
Interrupt:
  SerTxd( #pinsC, " " )
Interrupt_Enable:
  SetInt OR 0x06, 0x07
  Return
