A animal2 New Member Jan 1, 2008 #1 Set Paths, Under System, does not save Initial folder settings. On start up Default Window is Active
Technical Technical Support Staff member Jan 3, 2008 #2 Seems to work for us, can you be more specific on the issue? You need to restart VSM for the new settings to work.
A animal2 New Member Jan 4, 2008 #3 Re After setting "Initial Folder is always the following", then save preferences, then exit Program. On startup again it defaults to "Intial Folder is taken from Windows"
