This project takes a signal from a hobby RC radio receiver, manipulates the signal, then outputs to a servo.
The user can set up the following by pressing a button on the board:
Neutral position
Maximum travel
Minimum travel
Failsafe position
I use it to extend servo travel by up to 180° for use as a model boat sall winch.
Schematic and PCB layout (Visio drawn) attached.
The only problem that I have found is that the failsafe position does not exactly match the position selected during the setup procedure. Technical have confirmed that this is due to a small difference in the pulsout and servopos timings. It may be possible to calibrate this out in code.
Neutral position
Maximum travel
Minimum travel
Failsafe position
'Servo end point adjustor and fail-safe
'Kevin Goom, 4 April 2009
'PICAXE-08M connections are:
' Leg 1 +5V
' Leg 2 (Serial in) Tie to ground through 10K resistor
' Leg 3 (In4/out4/ADC4) Pulse input from radio receiver through 330 ohm resistor
' Leg 4 (In3) Momentary push switch to 5V & 10K to ground
' Leg 5 (In2/out2/ADC2) Wiper of 10K pot, other pot legs to +5V & ground
' Leg 6 (In1/out1/ADC1) Pulse output to servo.
' Leg 7 (Out0/Serout) LED anode, cathode through 470 ohm to ground
' Leg 8 (Out5) Ground
symbol PW_In=w0 'Name the input pulse width
'b2 not used
symbol PW_In_Old=b3 'Name the previous input pulse width
symbol Scale_H=b4 'Name the scale factor for positive servo rotation
symbol Scale_L=b5 'Name the scale factor for negative servo rotation
symbol Pot_ADC=b6 'Name the ADC pot reading
'b7 not used
'b8 used in 2 counter loops
symbol Flash_Times=b9 'Name the number of times to flash the indicator during setup
symbol PW_Default=b10 'Name the pulse width when signal is lost
symbol PW_Null=b11 'Name the null position input pulse width
symbol PW_Out=w6 'Name the output pulse width
setint %00001000,%00001000 'Trap setup input on In3, Leg4
eeprom 0,(150,80,80,150) 'Set default values to be used before calibration is run
read 0,PW_Null 'Read null pulse width previously stored
read 1,Scale_H 'Read scale factor for positive servo rotation previously stored
read 2,Scale_L 'Read scale factor for negative servo rotation previously stored
read 3,PW_Default 'Read scale factor for defaultservo rotation previously stored
Main_Loop:
pulsin 4,1,PW_In 'Measure the input pulse width
if PW_In>75 and PW_In <225 then Input_Valid 'Exit loop & continue if valid pulse detected
servo 1,PW_Default 'Initiate servo pulse train
Invalid_Loop:
servopos 1,PW_Default 'Set servo to previously stored value on signal loss
if PW_In<76 or PW_In >224 then Invalid_Loop
Low 1 'Turn off servo command
goto Input_Valid
Input_Valid:
If PW_In_Old>PW_In then
b8=PW_In_Old-PW_In
b8=PW_In-PW_In_Old
if b8<2 then Skip '1 unit of hysteresis to prevent servo jitter
PW_In_Old=PW_In
Gosub Calc
Skip:
pulsout 1,PW_Out
goto Main_Loop
Calc:
if PW_In>=PW_Null then
PW_Out=PW_In-PW_Null*Scale_H/80+PW_Null
PW_Out=PW_Out max 250
PW_Out=PW_Null-PW_In*Scale_L/80
PW_Out=PW_Null-PW_Out min 40
Setup:
Pause 1000 'Pause allow time for button release
Setup_Center:
pulsin 4,1,PW_Null 'Measure input pulse
pulsout 1,PW_Null
if pin3=0 then Setup_Center'Keep reading input pulses until setup button pressed
write 0,PW_Null 'Store the center position pulse width
Flash_Times=1
gosub Flash 'Indicate setup of center position has been completed
Setup_max:
pulsin 4,1,PW_In
Readadc 2,Pot_ADC
Scale_H=Pot_ADC*100/128
Gosub Calc
pulsout 1,PW_Out
if pin3=0 then Setup_max 'Keep reading ADC until setup button pressed
write 1,Scale_H 'Store the positive rotation scale factor
Flash_Times=2
gosub Flash 'Indicate setup of positive rotation has been completed
Setup_min:
pulsin 4,1,PW_In
Readadc 2,Pot_ADC
Scale_L=Pot_ADC*100/128
Gosub calc
pulsout 1,PW_Out
if pin3=0 then Setup_min 'Keep reading ADC until setup button pressed
write 2,Scale_L 'Store the negative rotation scale factor
Flash_Times=3
gosub Flash 'Indicate setup of negative rotation has been completed
Setup_Default:
pulsin 4,1,PW_In
gosub Calc
pulsout 1,PW_Out
if pin3=0 then Setup_Default'Keep reading pulses until setup button pressed
PW_Default=PW_Out
write 3,PW_Default 'Store the pulse width for loss of signal
Flash_Times=4
gosub Flash 'Indicate setup of signal loss default has been completed
low 0 'Turn off setup indicator
low 1 'Turn off servo command
Flash: 'Indicate value has been read and stored
for b8=1 to Flash_Times
low 0
pause 500
high 0
pause 500
Next b8
Interrupt:
high 0 'Turn on setup indicator
gosub Setup
setint %00001000,%00001000 'Reset interrupt
