I've been using the "servo" command to drive an inexpensive R/C servo. I also generate a ramped reference using "for-next". My problem is that the servo "jerks" as it follows the increasing pulse width reference. When I scope the reference pulses, the ramp is smooth from .5 msec to 2.25 msec, no stuttering. I've also tried using the PWM command to ramp the reference from .5 to 2.25 msec with the same results. The for/next loop counts 175 times in 5 seconds to provide the ramp slope; the increments should be invisible to the naked eye, but the rotation can be seen incrementing at about 5 times per second. Any thoughts?
Thanks,
walt
Thanks,
walt
