A amewsaj Member May 7, 2009 #1 Does serrxd stop the internal timer? As soon as I add the serrxd line, the timer stops counting. Anything I can do about it?
B BeanieBots Moderator May 7, 2009 #2 Read Technical's reply to this:- http://www.picaxeforum.co.uk/showthread.php?t=12369
A amewsaj Member May 7, 2009 #3 Thanks.... Though, as soon as I do these lines pause 2000 hsersetup B4800_4, %00 end The in6 flashes on/off every 2 second. How can hser... affect anything but the serout and serin ports. Last edited: May 7, 2009
A amewsaj Member May 7, 2009 #4 Oh, now I see hser... has some dedicated pins. I can't use that. No free pins. Any other solution? Manually add to the timer when using sertxd.. ? (Bad, but wouldn't it work..)
