kieran_akers
this is a follow up to my earlier question (cheers for advice) when sending info from the serout i read that you could send out ascii code. the script im using is:
let b0 = "a"
serout 1, n2400, (b0)
I presumed that as the value of b0 had been set as a it would send the ascii code for the letter a out to the other device. is this correct, or do i need to get "b0" to equal the ascii code for a (i.e. decimal value 65)
let b0 = "a"
