I had plenty of headache with trying to run the 28X1 at 16 MHz with only 3.3V. I have an existing design (a time domain reflectometer) that uses a 28X and works just fine and is extremely reliable. I know that 3.3V at that speed is outside spec for the 28X1, but the low supply voltage is necessary to be compatible with the 3.3V high-speed PECL devices the design uses. When I tried to substitute a 28X1 for the 28X every other time I tried to write to the internal EEPROM it would write garbage, and also the serial connection would sometimes get corrupted (I didn't debug this too far but it seemed like sometimes characters were dropped). I tried with 3 different 28X1 devices, but every time the same result. Yes I do have proper power decoupling - lots of 10uF, 1uF, 0.1uF and 0.01uF capacitors across the board (this is >2 GHz design so I have to be careful). I also tried slowing it down to 4 MHz and even 1 MHz when writing to the EEPROM but no luck.
Now I even designed a daughter card that carries a 28X1, runs at 5V, but translates all the levels between 3.3V and 5V. I expected this to work, but same issue - unreliable sertxd/serrxd, and problems with writing to the EEPROM.
Looks like I'll have to stick with the 28X for this project, which is a pity because I could really need the 20 MHz and the hserout to speed up operation.
Wolfgang
