premelec
I have seen reference many times to noise on simple receiver modules hanging up SERIN which evidently just stays active looking at the noise - Is this correct? [command description doesn't seem to address this].
erco recently referenced http://www.romanblack.com/RF/cheapRFmodules.htm which gives a detailed analysis of some cheap modules - from this write up it appears there is an AGC function [Auto Gain Control] which quiets the noise if there is a strong local signal and holds the gain down for a while after the signal is gone - It would seem that PULSIN could be used to look for a long carrier input setting back the AGC and then switch to SERIN or simply record subsequent PULSIN values which could be used to control something by their length... Does this seem a viable strategy? [and I'm not clear on just what terminates a SERIN]
I've got some of these $1 modules and will try some things - the only thing I've discovered so far is how unstable the TX frequency is by listening with a good communications receiver - not a really narrow bandwidth so presumably the RX is also pretty broad.
Your comments welcome - thanks...
