it just depends on the application the internal osccilators are still usable for quite a bit just some of them are useless for serial and high accuracy timing applicationsI have 2X 40X1's running on a pcb with a GSM module. I used the internal res and had no end of trouble with serial comms to and from the GSM module. I spent about 16 hours trying different programming approaches.
I solderd on 16mghz extenal res. and the problems stopped immediately. I would never again rely on the internal res. for anything other than flashing a few LEDs or something simple like that.
The internal oscillator of the 28X1 seems to be as tightly spec'd as an 08M so that shouldn't be a problem, and as the problem can be solved by going from an accurate external resonator / crystal to less accurate internal clock and adjusting its speed with CALIBFREQ that suggest it's not an oscillator problem per se.For the sake of a couple of extra bits of wire on the bread board or a couple of tracks on a pcb design I'd go the external and then have the peace of mind I had that part covered.
