Michael 2727
Not wanting to mess up the current thread, serial serial sertxd on 18X, etc.
SEROUT- on the Download Output Pin.
Have I been doing it the wrong way all this time ?
(wouldn't be the first, and probably not the last ~ ;o)
From the picaxe Manual2.pdf
An additional mention in the Manual wouldn't go astray I think.
On my Schools Experimenter board, AXE092, with an 08M chip
( Pin0 on the 08M is the SERIAL OUT pin )
I have been quite happily using the download cable (Stereo Socket )
for downloading new programs, then when needed using the exact
setup for sending data back to the Terminal app or SelmaDAQ.xls
and maybe a couple of other apps. (No jumper pins on the axe092 )
I don't seem to have had any problems that I've noticed.
I don't use SEROUT very often though.
I have had a search but did not really turn up anything on this subject.
I gather some output formats may not work properely ?
I don't have a variety of other chips to to test either.
Any info appreciated,
Michael
Could someone please elaborate on what issues may occur here.SEROUT
Information:
The serout command is used to transmit serial data from an output pin of the
microcontroller. It cannot be used with the serial download output pin - use the
sertxd command in this case
Michael
