Hi
I have been experimenting with a Robertsonics WAV Trigger for mixing audio tracks using the serial output from a Picaxe 08M2 to control it.
robertsonics WAV Trigger
I have been successful in controlling most functions on the such as Start / Stop / Pause / Resume / Loop tracks, however I am having problems controlling volume which I need to fade between tracks. The volume control for each track needs to be set between -70dB and +10dB using a signed integer. The serial protocol format from the online documentation is
- VOLUME
- Message Code = 0x05, Length = 7
Data = Volume (2 bytes, signed int, -70dB to +10dB)
Response = none
Comments: Updates the output volume of the WAV Trigger with the specified gain in dB
Example: 0xf0, 0xaa, 0x07, 0x05, 0x00, 0x00, 0x55
