djsoftlayer
Hi what do you recomend me to send AT command with the picaxe 18X, i mean, using the programing port of the picaxe or other, how to emulate the structure of an AT command because i read that they need an structure:
"The attention or “AT” prefix is required prior to entering any command. All commands require a carriage return or <CR> following the entry of the desired command. All command responses are encapsulated by a carriage return and line feed or <CR><LF>. The ASCII display of these characters is suppressed with only the modem response being presented.
AT message concatenation can be done using the ; <semicolon> between commands."
I need to control a GSM modem at 4800bps with a picaxe 18X... Thanks!!! sorry about my english
