I wonder if you could add another wire to the top of your fence posts, as in my rough drawing attached (!). This wire would be free to move, through a loosely hammered in U shaped tack. The wire would be fixed to one post, then run say 500' through many posts to a spring tensioner. At the tensioner is a picaxe unit with a microswitch to detect if the wire has been depressed, with radio link etc. So have a unit every 500', all communicating with a central unit.
OR, another cunning idea ...
Instead of many picaxe units, just have the microswitch and a resistor at the tensioner. Wired as per ....
o
.--o--.
\ o .-.
\. | | Unique resistor value
Microswitch o '-'
'--o--'
Normally closed |
o
The wire itself with these microswitch/resistor combinations form a complete circuit around your property. Make each resistor a unique value. Have just one Picaxe unit in your house that reads the resistance of the circuit via an ADC input.
Because each resistor is unique value, and is only brought in circuit if the wire is depressed, it should be possible to pinpoint the sector that is being breached !
Ok, I can see possible issues with the inbuilt resistance of the long long wire circuit, plus pickup of noise etc - but it might just work. Plus would possibly be a lot cheaper?? (cost of picaxe 08M, piezo buzzer , serial display and box <£20, cost of 5 miles of wire £100+ LOL!)
