buntay
Hello all, I have been through the manual and checked over my code but I cant find my error. The manual says that a word value uses 2 byte values....ie b0+b1=w0. so wouldn't b8+b9=w4 and b10+b11= w5?
here is what I am tryin to do. I have a 28x2 that is running code and I am using a 18m2 as a adjustable timer ( yes there are other ways but these are what I have on hand) looking at the code you can see how the timer works. Now, I using this timer in conjunction with a counter algorithm to gauge a "time to empty" loop.
well here is code and any help would be appreciated.
setfreq m16
'variables used
'b0
'b1
'b2
'b3
'b4
'b5
'b6
'b7
'b8\
'b9/====W4
'b10\
'b11/===W5
'b12
'b13
symbol stoker = b.0
symbol blower = b.1
symbol auger = b.2
symbol aux = b.3
symbol alarm = b.4
symbol lcd=b.5
symbol wifitx=b.6
symbol wifirx=b.7
symbol stokerpm = c.0
symbol blowerpm = c.1
symbol augerpm = c.2
symbol thermostat = pinc.3
symbol augprox =pinc.4
symbol reboot = pinc.5
serout lcd,T9600_16,("CL") 'Clears screen
serout lcd, T9600_16, ("STCR",20,4,128,192,148,212) 'sets screen for 20x4
pause 7000
serout lcd,T9600_16,("CS0") 'Turns Curser Off
Start:
low stoker
low blower
low auger
low aux
low alarm
w5=10000
serout lcd, T9600_16, ("CL","TT")
serout lcd, T9600_16, ("Begining System Tests",cr)
pause 5000
pause 3000
serout lcd, T9600_16, ("Testing Stoker Motor",cr)
high stoker
count stokerpm,1000,b0
if b0 > 5 then
serout lcd, T9600_16, ("Stoker Motor Passed",cr)
serout lcd, T9600_16, ("Stoker Failed",cr)
end if
low stoker
pause 3000
serout lcd, T9600_16, ("Testing Blower Motor",cr)
high blower
count blowerpm,1000,b1
if b1 > 5 then
serout lcd, T9600_16, ("Blower Motor Passed",cr)
serout lcd, T9600_16, ("Blower Failed",cr)
end if
low blower
pause 3000
pause 3000
serout lcd, T9600_16, ("Testing Bin Auger",cr)
high auger
count augerpm,1000,b2
if b2 > 5 then
serout lcd, T9600_16, ("Bin Auger Passed",cr)
serout lcd, T9600_16, ("Bin Auger Failed",cr)
end if
low auger
pause 3000
'if b0<5 then goto stokerdown
'if b1<5 then goto blowerdown
'if b2<5 then goto augerdown
serout lcd, T9600_16, ("Box Temp",cr)
serout lcd, T9600_16, ("TP",0,1,"TT")
serout lcd, T9600_16, ("Incoming Temp",cr)
runsys:
b0=0
b1=0
b2=0
b3=0
b4=0
b5=0
b6=0
b7=0
'serin [1000],wifirx,T9600_16, b6
if b6= "a" then goto commands
if reboot =1 then reset
end if
readtemp a.0,b0
b12=b0 *9/5+32
if b12 <100 then
serout lcd, T9600_16, ("TP",17,0,"TT ")
serout lcd, T9600_16, ("TP",16,0,"TT ")
end if
serout lcd, T9600_16, (#b12,cr)
readtemp a.1,b1
b13=b1 *9/5+32
if b13 <100 then
serout lcd, T9600_16, ("TP",17,1,"TT ")
serout lcd, T9600_16, ("TP",16,1,"TT ")
end if
serout lcd, T9600_16, (#b13,cr)
if thermostat = 1 then goto heat
if thermostat = 0 then low stoker
if b0<90 then goto cooldown
if b0>90 and b0<218 then high blower
if augprox = 1 then high auger
count augerpm,1000,b3
if b3<3 then goto augerdown
else low auger
end if
end if
end if
pause 3000
goto runsys
heat:
if b12>90 and b12<218 then high blower
end if
if b12>220 then low stoker goto overheat
high stoker
end if
overheat:
else low auger
end if
if b12<90 then low blower
end if
'count stokerpm,1000,b2
'if b2<5 then goto stokerdown
'count blowerpm,1000,b3
'if b3<5 then goto blowerdown
if pinc.7=1 then high c.6:w4=w5 - 1 'uses a seperate picaxe as a timer to count down coal use
else low c.6 'to gauge coal left in the bin
end if
if w4 <900 then serout lcd, T9600_16, ("TP",18,3,"TT ",cr)
end if
if w4 <800 then serout lcd, T9600_16, ("TP",17,3,"TT ",cr)
end if
if w4 <700 then serout lcd, T9600_16, ("TP",16,3,"TT ",cr)
end if
if w4 <600 then serout lcd, T9600_16, ("TP",15,3,"TT ",cr)
end if
if w4 <500 then serout lcd, T9600_16, ("TP",14,3,"TT ",cr)
end if
if w4 <400 then serout lcd, T9600_16, ("TP",13,3,"TT ",cr)
end if
if w4 <300 then serout lcd, T9600_16, ("TP",12,3,"TT ",cr)
end if
if w4 <200 then serout lcd, T9600_16, ("TP",11,3,"TT ",cr)
end if
if w4 <100 then serout lcd, T9600_16, ("TP",10,3,"TT ",cr)
end if
if w4 <50 then serout lcd, T9600_16, ("TP",9,3,"TT ",cr)
end if
if w4 <25 then serout lcd, T9600_16, ("TP",8,3,"TT ",cr)
end if
if w4 <12 then serout lcd, T9600_16, ("TP",10,3,"TT EMPTY",cr)
end if
'_______________________________________________________________________________________
serout lcd, T9600_16, ("TP",0,2,"TTCount down ",#w4,cr)
w5=w4
goto runsys
cooldown:
b4=0
b5=0
readtemp a.0,b4
if b0<85 then low blower:goto done
end if
count blowerpm,1000,b5
if b4<5 then goto blowerdown
done:
goto runsys
stokerdown:
pause 1500
serout lcd, T9600_16, ("Furnace Off")
serout lcd, T9600_16, ("TP",0,1)
serout lcd, T9600_16, ("Stoker Error",cr)
stokerdown1:
high alarm
low stoker
low blower
low auger
end if
b6=0
low alarm
pause 1500
goto stokerdown1
blowerdown:
pause 3000
serout lcd, T9600_16, ("Blower Error",cr)
blowerdown1:
high alarm
low stoker
low blower
low auger
end if
b6=0
low alarm
pause 1500
goto blowerdown1
augerdown:
high alarm
serout lcd, T9600_16, ("TP",0,3)
serout lcd, T9600_16, ("Auger Error",cr)
end if
b6=0
goto runsys
commands:
serout wifitx,T9600_16,("B",cr,lf)
'serin wifirx,T9600_16, b7
if b7= "1" then goto stokercontrol
if b7= "2" then goto blowercontrol
if b7= "3" then goto augercontrol
if b7= "4" then goto temps
if b7= "5" then goto shutdown
if b7= "6" then goto continue
if b7= "7" then goto systemstatus
if b7= "8" then goto auxcontrol
if b7= "9" then reset
end if
stokercontrol:
b6=0
b7=0
blowercontrol:
b6=0
b7=0
augercontrol:
b6=0
b7=0
temps:
b6=0
b7=0
shutdown:
serout lcd, T9600_16, ("CL")
shutdown1:
b0=0
b1=0
high alarm
readtemp a.0,b0
readtemp a.1,b1
low alarm
low stoker
low blower
low auger
low aux
serout wifitx,T9600_16,(b0,b1,cr,lf)
serout lcd, T9600_16, ("Furnace Down",cr)
goto shutdown1
continue:
b6=0
b7=0
goto runsys
systemstatus:
b6=0
b7=0
auxcontrol:
b6=0
b7=0
