rs232 driver
What you have posted is basically a schematic.
I feel you have a question but may need to elaborate on you problem or information.
what is the source (internet link) for the diagram you provided?
Tell us more and folks here can help.
Aries
As always, it depends on what you want to do. The HD44780 is a common LCD driver, and there are plenty of threads on this forum about it already, interfacing with various Picaxe chips. I use it with 20X2, 28X2 and 40X2 chips - usually via an 8-bit shift register to conserve Picaxe pins (in spite the thread I reference later), but you can connect 4 or 8 of the DB pins directly to a Picaxe. Look into some of the other threads, such as this https://picaxeforum.co.uk/threads/newbies-guide-to-parallel-hd44780-lcds-and-winstar-oleds-axe133-as-a-project-board.23707/ and then ask for more specific help.
Depori
Hey
de bedoeling is om een temperatuurmeter te maken volgens het voorbeeld van Marks
met een rs 232 schip, maar er is geen bouw van printplaat
