Hello,
I have purchased the 2-bit rotary encoders described in this thread, but I could not find a correct way of using them in the forum (I am sorry if I have missed some threads) : None of the code examples posted, that I have tried, gave me a usable result.
So, after some tests, I finally wrote this small piece of code that works perfectly with the above rotary encoders. The program has been written on a 08M, but should run on any Picaxe. In this example, the program detects the rotation direction and increment or decrement a counter.
I hope this will help.
Regards,
Christophe
'picaxe 08M
' +V 1 U 8 0V
' GND - 10K 2 7 (0) OUT
' I/O/ADC4 (4) 3 6 (1) I/O/ADC1 --- rotary encoder
' IN3 (3) 4 5 (2) I/O/ADC2 --- rotary encoder
' b1 b0 b3 b2 b5 b4 b7 b6 b9 b8 b11 b10 b13 b12
' --w0-- --w1-- --w2-- --w3-- --w4-- --w5--- --w6---
'b0 = bit7 : bit6 : bit5 : bit4 : bit3 : bit2 : bit1 : bit0
'b1 = bit15 : bit14 : bit13 : bit12 : bit11 : bit10 : bit9 : bit8
#rem
Rotary encoder connection:
0V
4.7K
o--.---- pin1 (phys 6)
o--330-- +5V
o--.---- pin2 (phys 5)
4.7K
0V
Encoder result (early detection):
pin1 pin2
1 0 one direction
0 1 other direction
0 0 init and final (= "detent") status
One direction: pin1 goes high before pin2
___ ___
pin1 ___| |___| |___
___ ___
pin2 _____| |___| |___
Other direction: pin2 goes high before pin1
___ ___
pin1 _____| |___| |___
___ ___
pin2 ___| |___| |___
#endrem
' Used bits xxxx xxxx
symbol getBits = b0 'b0 = bit7 : bit6 : bit5 : bit4 : bit3 : bit2 : bit1 : bit0
symbol dir = b1
symbol counter = b3
setint %00000010,%00000010 'interrupt on pin1 high only
sertxd("Main loop - Counter=",#b3,13,10)
interrupt:
bit2 = pin2: bit1 = pin1 'save rotary encoder pins status
getBits = getBits & %000000110 'isolate rotary encoder pins
if getBits <> 0 then 'if both pins are low, the direction is undetermined: discard
dir = bit2 * 2 'direction: if bit2=low then dir=0; if bit2=high then dir=2
counter = counter - 1 + dir 'change counter variable accordingly
do while getBits <> 0 'wait for the encoder to go to the next "detent" position
getBits = pins & %000000110
setint %00000010,%00000010 'restore interrupt on pin1 high
Christophe
