I have a rotary encoder and used some code from Hippy and some other posts that works well apart from 2 points below. The code will be used to set 2 values for a program to refer to. It is for my brewery where two temperatures are preset by the user.
I'm using a picaxe 40x2 and a 4 row OLED screen.
1. Can only increase the counter value when turning clockwise or anticlockwise (not sure what I missed in the posts but can't get it to decrease)
2. I can't get both the counter values to write to memory - only the second
The rotary encoder is used to increase the temp on the display OLED. Encoder switch takes user to a screen showing new temp has been set to "x". The user selects the next value for the second temperature and hits the rotary switch taking them to the screen showing the second value preset. Pause in the code for 5000 then show both new preset values.
This all works fine except I have added pinc.2 as a switch on start up to take the user to "Test" which should show the two temp values saved to internal memory so I can check that they have saved. The problem is that both values are equal to the second or last value preset. and the first is lost.
Many thanks
Phil
pins b.0 and b.1 for the two signal pins on the encoder and pinc.3 for the switch
#Picaxe 40X2
; 21-
Symbol IRQ_A = %010 ; Signal A = pin B.0 HINT1
Symbol PIN_B = pinB.1 ; Signal B = pin B.1
Symbol counter = w0 ; b1:b0
Symbol detect = b2
Symbol thisCount = w2 ; b5:b4
Symbol lastCount = w3 ; b7:b6
symbol OLED1 = d.7
symbol ROTstrikesave = b22
symbol ROTspargesave = b15
if pinc.2 = 1 then goto test 'If pinc.2 is high on start up got to test
MainProgram:
serout OLED1,N2400,(252,1)
pause 30
pullup on
Gosub Interrupt_Enable
Do
if pinc.3 = 1 then goto saved 'if rotary switch is high goto saved
thisCount = counter
If thisCount <> lastCount Then
lastCount = thisCount
If thisCount >= $8000 Then ; Negative
thisCount = -thisCount
write b16, word thiscount 'write thisount value into b16
serout d.7,N2400,(254,128,"Set Stike Temp:",#thiscount,%11010010,"C ")
End If
End If
Loop
saved:
read b16, ROTstrikesave ' read b16 into ROTstrikesave
pause 30
serout OLED1,N2400,(254,128,"New stike Temp will ",254,192,"be saved at: ",#ROTstrikesave,%11010010,"C ",254,148," ",254,212," ")
SETINT OFF ' set interupt off so that program can move to mainprogram2
pause 2500
mainprogram2:
let counter = 0 ' let counter = 0 so new value to be preset starts with 0 rather than previous preset value
serout d.7,N2400,(254,128,"Set Sparge Temp:",#thiscount,%11010010,"C ",254,192," ",254,148," ",254,212," ")
pause 30
pullup on
Do
if pinc.3 = 1 then goto saved2
thisCount = counter
write b17, word thiscount
serout d.7,N2400,(254,128,"Set Sparge Temp:",#thiscount,%11010010,"C ")
End If
End If
Loop
saved2:
SETINT OFF
read b17, ROTspargesave
pause 30
serout OLED1,N2400,(254,128,"New Sparge Temp will ",254,192,"be saved at: ",#ROTspargesave,%11010010,"C ",254,148," ",254,212," ")
Pause 5000
serout OLED1,N2400,(254,128,"New Strike is: ",#ROTstrikesave,%11010010,"C ",254,192,"New Sparge is: ",#ROTspargesave,%11010010,"C ",254,148," ",254,212," ")
pause 5000
test:
serout OLED1,N2400,(254,128,"New Strike2 is: ",#ROTstrikesave,%11010010,"C ",254,192,"New Sparge is: ",#ROTspargesave,%11010010,"C ",254,148," ",254,212," ")
pause 500
goto test
end
Interrupt:
counterdetect:
counter = detect / 16 Max 1 ^ PIN_B * 2 - 1 + counter
Interrupt_Enable:
detect = IRQ_A * 16 ^ detect | IRQ_A
flags = 0
HintSetup detect
SetIntFlags IRQ_A, IRQ_A
Return
Many thanks
Phil
#Picaxe 40X2
; 21-
Symbol detect = b2
symbol OLED1 = d.7
MainProgram:
pause 30
pullup on
Do
thisCount = counter
End If
End If
Loop
saved:
pause 30
pause 2500
mainprogram2:
pause 30
pullup on
Do
thisCount = counter
End If
End If
Loop
saved2:
SETINT OFF
pause 30
Pause 5000
pause 5000
test:
pause 500
goto test
end
Interrupt:
counterdetect:
Interrupt_Enable:
flags = 0
HintSetup detect
Return
