Just wanted to share my admittedly garbage rotary encoder code. If someone has anything better, please feel free to share:
I'm using an encoder that has a common and 2 pins that use a Gray code to pulse out the direction. Sparkfun has a similar one at http://www.sparkfun.com/commerce/product_info.php?products_id=9117. It's expecting the A/B inputs of the encoder on Input6 and Input7. This uses the pseudo Interrupts to get the data, setting them to goff a change on the 'A' pin. This means you're only getting 1/4 the resolution available, but the Picaxe was having a hell of a time keeping up when I tried a full quadrature decode.
Symbol ENC_A = Input7
Symbol ENC_B = Input6
Symbol ENC_INT_PIN = %10000000
Symbol ENC_INT_PASK = ENC_INT_PIN ^ $FF
Symbol Val = b1
Symbol ENC_UP = 2
Symbol ENC_DOWN = 1
Symbol ENC_OOPS = 0
Symbol LED = 0
Start:
Val = 127
SetFreq m8
' Chosen because 0-100% = 0 - 1023
pwmout 3 , 255, 512
' Set the interrupt for the oposite edge
b0 = ENC_A * ENC_INT_PIN
b0 = b0 ^ ENC_INT_PIN
SetInt b0, ENC_INT_PIN
MainLoop:
Pause 50
GoTo MainLoop
interrupt:
High LED
If ENC_A = 1 Then
if ENC_B = 1 Then
Val = Val - 1
Else
Val = Val + 1
EndIf
SetInt 0, ENC_INT_PIN
Else
if ENC_B = 0 Then
Val = Val - 1
Else
Val = Val + 1
EndIf
SetInt ENC_INT_PIN, ENC_INT_PIN
EndIf
W1 = 0
b2 = Val
W1 = W1 * 4
pwmout 3 , 255, W1
Low LED
Return
