premelec
RFIN examples show the necessary 8 bytes received as b0 b1....b7; understood... however is it ok to receive, for example b0 b0 b0 b0 b1 b1 b1 b1 to conserve variable use and receive only two new values? I'm not up on how the Manchester code works... and if it's ok to keep replacing the same variable value or if the 8 variables need different values to confirm correct reception. Thanks
