Hi all,
I'm hoping you can help with some info on RFID.
I have picked up a sensor unit labelled "ID-12 Innovations 05110030" and a small key fob unit.
The sensor is already attached to a small PCB with clearly labelled connections for 0V, +V and Output.
The unit has 10 connections but only 5 are actually connected to the PCB.
I have connected the unit using 4.5v across 0V and +V and then put a multimeter across 0v and the output in the hope that putting the key fob close to it would give a varying voltage.
The output voltage appears to be 50mV but placing the key fob close (or even touching) does not affect the voltage reading.
So am I along the right lines in terms of testing? Could there be a battery issue with the key fob? Is 4.5v correct for the sensor unit etc etc?
I have included some pics.
Cheers in advance,
Andy
Cheers in advance,
Andy
