Hi. I'm trying to find the best way to quickly output one pulse after receiving two pulses with a 08m2.
I'm building a circuit for my car's tacho. 4 cylinder engine was replaced with an 8 cylinder engine and the tacho is reading double the RPM. The tacho signal is a square wave tied high, dropping low for each spark plug fire (measured it with a scope and it seems that the ''low'' part is the same width at any engine speed). Its a ~12V wave, so I'd probably need to use transistors or FETS both to receive the signal and to output it.
What do you people think would be the best way to tackle this (I'm quite new with this, so both hardware and software ideas are welcome)?
