Hi PiX,
Welcome to the forum.
Your question is way above my pay grade.
However, you will be asked to supply all relevant information, regarding your query.
Like your program & voltage supply.
Good luck, Bear..
However, if you want to avoid clearing any data, you can use the RUN command. The manual erroneously says it's only available on the X2 Series, but it works fine on the 14M2 I just tried.
