ChedderCheeser
hi all. I am going to be working with a icaxe 40X2 and a 4Mhz resonator. I am confused on this though... do I need any extra code to get the maximum speed out of it or... does it just.. automatically do it?
You mean PICAXE-40X2I am going to be working with a icaxe 40X2
Internal or external? I'll assume externaland a 4Mhz resonator.
You need to use the SETFREQ command to use anything other than the internal 8MHz oscillator although unfortunately it will automatically go back to 8MHz if there's a problem with the external resonator (which is a pain on battery supplies or ones with big capacitors). the PICAXE-40X2 has an option for an internal oscillator at 16MHz so unless you need the extra timing accuracy offered by an external one, I suggest you use the internal one.I am confused on this though... do I need any extra code to get the maximum speed out of it or... does it just.. automatically do it?
