relay not working
novolts
Hi Guys
Advice would be greatfully received
I cannot get my basic relay circuit to work in VSM , I have placed a 5 volt relay (from the library ) connected via a push button switch
connected to a 6 volt battery
thanks
novolts
novolts
Thank you for the reply I will send the .dsn file
What I should have said in my previous thread I am able to simulate the "picaxe relay" but none of the other relays simulate from the library
kind regards
novolts
novolts
Hi Guys
in simulation Relay 1 operates (picaxe relay ) however Relay 2 does not operate
any advice would be appreciated
thanks
novolts
Relay 2 is operating; it is just that its contacts are not animated like those of Relay 1 are.
Put a voltage through the switch contacts and measure the voltage the other side or light a LED and you will see that it does switch.
