rob.beckett
Hello,
Ive made up a variboard with 7 relays on it. I'm planning on using the relay interface circuit as found in the manuals.
The relays are 5v but wanted them on a separate battery to the PIC, so there is just an input from the pic with the 0v common.
When I plug in my battery ( with the picaxe board not connected) one of the relays picks. Only one, the rest behave how i'd expect. ie not pick until the pic outputs to turn on the thyristor.
This is really strange, I've checked the soldering over and over, and then restarted everything. but still one relay picks.
Just wondering if anyone else has had this problem when dealing with several relays next to one another?
Its like a voltage is being induced from somewhere.
Ive got 5v rails and 0v rails and am sure that there are no interconnections.
Does anyone think that it could be the thyristor failing?
Thanks in advance for any help!!
Rob
Rob
