Reading FSRs without ADC
Anobium
I am trying to use the approach shown at the bottom of this web page http://www.ladyada.net/learn/sensors/fsr.html to read the value of the FSR.
When I calibrate using a 10K Analog pot I get 4 values shown in the terminal of 0,1,2 and 3. These values are representative of the value of the pot. However, i would have expected more values to be returned.
Is the cause of the limited return values (0,1,2 and 3) the Picaxe clock speed? So, if I change the Picaxe to a faster option I would get more granular return values?
Any thoughts (relating to this subject please....).
Thank you.
Anobium
My layout is attached and the code shown below.
' 1uf CAP with 10K resistor
' 08m
setfreq m8
symbol timer = w1
	dirs = %00000010
	low 1
	' Charge CAP
	pause 5
	timer = 0
	dirs = %00000000
	do while pin1 is off
		timer = timer + 1
		if timer = 1028 then
			sertxd ("*")
			goto fin
		end if
'	debug
	fin:
	sertxd (#timer,13,10)
I'd say forget about doing it the way you are and use one of the other resistive divider methods instead, then it's a simple case of using READADC.
The timed charge-discharge method is best suited to micros which don't have ADC when there's no other way to do it.
Anobium
I will use READADC but is the clock speed the cause? I am genuinely interested to understand the results I obtained.
Yes, probably clock speed and fast rate of of discharge. That time can be roughly calculated as T=RC so, T= 1x104 x 1x10-7 = 1x10-3 = 1ms, and it's going to be less than that. So things to increase the count -
Larger capacitor
Faster PICAXE speed
Remove extraneous code from the counting loop
Use "Do ... Loop While/Until" rather than "Do While/Until ... Loop"
And for best results use an internal timer/ counter running at high speed..
You're only charging the capacitor for 5 mS. Do you have 'scope to see how much of a charge it gets in that time? Is the charge current peak within the safe limits of the PICAXE?
Anobium
I will get my scope out and look at the charging rates when I get a moment this week.
I did not show the 220ohm current limiting resistor that I have between this circuit and the Picaxe - an error in the diagram. This is the circuit Psuedo ADC.jpg
This thread may also be of interest ...
http://www.picaxeforum.co.uk/showthread.php?11991-Capacitance-meter
My code for doing the charge-discharge timing is in post #6 and uses an internal timer. The technique is to discharge so the reading is low on a digital input pin, charge until it goes high, then switch to discharging and measure the time until low again. That automatically gives the initial timing and fairly consistent repeatable measurements. I used one control pin ( charge, discharge, floating/disconnected ) and another to read the input,
