L lake New Member Jul 23, 2007 #1 hi i need to read a var value b0 to the output pins but not the standard pins but the pinsc whats the code i need to use to do this thanks Edited by - lakey009 on 23/07/2007 19:49:01
Technical Technical Support Staff member Jul 23, 2007 #2 let pinsc = b0 You have to make sure the relevant portc pins are outputs first though, using let dirsc = xxx See the appendix at the end of manual part 1
L lake New Member Jul 23, 2007 #3 thanks alot just thought there could be a command like read b0 , pinsc or something thanks for help
