Field strength meter. Some rambling thoughts.
Prompted by
http://www.picaxeforum.co.uk/showthread.php?t=11463&page=4
postings # 29 – 32.
Use a quick simple FSM, for example:
http://www.zen22142.zen.co.uk/Circuits/rf/sfsm.htm
Instead of the DMM, use a simple Op Amp and ReadADC10 Picaxe circuit.
Transmit the values over a “standard” Picaxe 433 MHz arrangement.
Scenario 1.
I'm at home, with my transmitter and I'm adjusting my new Tx antenna.
The fixed receiver / FSM sends me data.
Scenario 2.
I go walkabout, carrying the transmitter. I log my position on a map.
The home receiver sends me info. I write it down.
Scenario 3.
Going further, using Eeprom (and even GPS)
for an automated logging system to make your own Polar Diagrams.
I know it's done for “real”, by the professionals, using “serious” equipment,
but, AFAIK, not yet with a Picaxe.
(And, this could all be breadboarded and re-cycled.)
And, if it doesn't work, you've still had a walk in the fresh air.
e
PS 1. It could also be done using a receiver with RSSI
PS 2. OA91 diode example
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Signal-Diodes/OA91-Germanium-point-contact-diode/73379/kw/germanium
(I'm sure there are many alternatives.)
Prompted by
postings # 29 – 32.
Scenario 1.
Scenario 2.
Scenario 3.
e
