Quick duplication with Blockly
Technoman
#1
In flowchart mode, you can quickly duplicate a block by pressing the Ctrl key and dragging the block.
Is it possible to add this feature for Blockly?
Technoman
#3
In flowchart mode, you normally need a copy/paste to duplicate as there is no duplicate command. Fortunately, the Ctrl+drag block is very efficient in providing you with multiple copies.
The Right click > Duplicate with Blockly is not as efficient.
Technoman
#4
The duplicate command is limited to one block. A multiple blocks selection and copy capability would be an appreciated feature.
A workaround for multiple copy of blocks uses the nested blocks principle :
- keep a loop block in a corner
- insert into it all the blocks you need to duplicate
- duplicate the loop with the inserted blocks
- remove the second loop
