here is my code. I have tried to do the
thing but can't get to work
main: do
do : loop until pinc.1 = 0 ' loop until the pin goes low
pinc.1 = 1 'pin b.1 goes low via push button switch 1
toggle b.3 'energizes a led1
pause 75 ' led is 0n for 75ms
toggle b.3
gosub tr2a
tr2a: do
do : loop until pinc.2 = 0' loop until the pin goes low
pinc.2 = 1 ' goes low via push button switch 2
toggle b.5 'energizes led2
pause 75 'led is on for 75 ms
toggle b.5
gosub main
This is just part of larger code that i am working with. I wired the entire project on a bread board and it works perfectly.
there is no problem with the code.
Now i want to make a permanent circuit on a prototype board.
here is how it is wired. chip is powered, pin c.2 has a 1k ohm resister to 5v, 0v to the switch and the other side to pin c.2. pinc.3 is wired similarly . b.5 is wired to an led, b.3 is wired to a second led. when wired to a bread board it works great. plug in the Same chip on the prototype board and it won't work. I have 5 v going to pin c.2 and c.3, when i push the switch the volts drop to 0. I do not get any reading on pins b.5 or b.3. rework it on the bread board, it works perfect.
both are wired the same. why
