I have a 40X1 running a sensor. In protos I've been using the 40X1 mounted in a socket which is then soldered to the board. This allows changing the part if need be.
Has anyone had the experience of a IC vibrating out of socket in a in field application?
Has anyone had problems with the legs of the IC not making a good electrical connection with the socket after a long period of time in service?
Of course I can avoid all this by simply soldering the picaxe right into the board, problem is of course if there a problem with the part the whole board is a write off. Ive tried unsoldering a 40 pin part and getting it out, it aint easy no matter how much wick and sodler sucker you give it.
