Question for the panel?
!AndyT
In programming an 08M2 I have found that I am able to use PWM on C.1, C.2 and C.4 separately no problem.
I am trying to PWM two LED's independently one on C.2 and the other on C.4.
Does the panel know if this can be done?
Thanks in anticipation
!AndyT
If you mean, using the PWM command as opposed to the PWMOUT command, then yes you can control multiple LED's using PWM.
Whether you get satisfactory results will depend on what you want to achieve. The easiest way would be to try it and see.
