Can you tell us if the chip is a 08M2 or 08M2+ or maybe the older 08M ?I need to use the ReadTemp with an 8M chip.
Yep - read all that already. I guess I need to be in 3rd grade to understand what is perfectly clear as mud. Jeremy and I ran across a lot of that previously and had to use all sorts of notation to make decent notes. I'm sure there is a logical reason but ...Please see Manual 1 page 27.
You need an In / Out pin
I'll leave you to work out which 3. : - )
e
It's just one of those things. Leg numbering and pin naming never match - there is no leg zero - just that at the bottom left of the 8-pin chips the non-matching is more obvious, and it's sometimes easy to forget which one is talking about. Using the C.3 and C.4 naming it's not quite so bad.Makes sense that in 4 goes to 3 and in 3 goes to 4 ...
I was using an 8M chipIt's just one of those things. Leg numbering and pin naming never match - there is no leg zero - just that at the bottom left of the 8-pin chips the non-matching is more obvious, and it's sometimes easy to forget which one is talking about. Using the C.3 and C.4 naming it's not quite so bad.
Leg 3 = C.4, Input and/or Output
Leg 4 = C.3, Input only, doesn't support READTEMP
